Liked 10,914 Times in 2,256 Posts
A good friend of mine has a heads up in Stock second round. So for fun I looked at the HP rating of his competition. Much to my surprise the 1970 Camaro 350/360 in Super Stock was de-rated from 360hp to 325hp 12/19/02. I know the AHFS was in affect at that time and according to the rules: a competitor my have requested a reduction in Hp rating. The scale for reduction was based on the year’s previous runs by that combination. The reduction was written as 1.25% if the fastest run was quicker than -.165 under the National index and the class average was below -.550. If the quickest run was -.115 to -.164 under the reduction was 2.25%. So to receive a 35 Hp reduction using the 2.25 % I believe the start Hp would have to be 1555hp. Would y’all mind running the numbers to check my math. And for example a 15 Hp reduction on an engine rated at 420 the start Hp would have to be 666 Hp. I wonder how all this happened with the AHFS in affect?
Liked 359 Times in 135 Posts
Wouldn't the 420hp example have started out around 480 hp? I'm on par with Jethroe Clampett math wise though.
Who owns this car, with the peace sign,mag wheels, and four on the floor? |
Liked 20 Times in 14 Posts
If what you say is accurate about hp reduction then you are correct, 360hp at 2.25% should have received 8hp reduction not 35. been that way for 20 yrs Watched this race earlier and if not for a red light itwas going to be a close race! What does that say about the car's hp in the other lane? Both cars are fast and a LITTLE under factored!!!!! LOL
Liked 8,206 Times in 1,536 Posts
Larry, you don’t have a math problem …Your problem is Pat C ….If you need HP off a combo contact Jim Hale for help…he can work miracles….
Liked 7,864 Times in 1,750 Posts
Yeah, the 383 and 426 Street Wedge got about the same amount of "welfare".
Liked 804 Times in 168 Posts
This is just one example among many across all brands that this has happened to. It was over 20 years ago by Larry's info,, so who knows. This particular engine is the original LT1, 360 in a Camaro and 370 in a Corvette, in 71 they had less compression and were 320 and 330 if my memory is correct. I believe that the stock and SS rating may have been both lowered at the same time. There are some running in both stock and SS.
Dave Casey 1330 STK |
#7 | |
James Schaechter 3163 STK |
