Looking for a set of unmolested 083 cylinder heads for the 350 TPI motor. Call or text 252 67zero three three55
#2 | |
Liked 1,051 Times in 372 Posts
Sorry I do not have Tim Mather Sales Manager Clearwater Cylinder Heads, Inc 5100 Ulmerton Road Suite 2 Clearwater, FL 33760 Tel: 727-572-1958/ Fax: 727-556-2909 -----Original Message----- From: Clearwater Cylinder To: cchcylheads@aol.com Sent: Sat, Apr 22, 2023 12:27 pm Subject: Cylinder Head Request - Clearwater Cylinder [#8250] Name * Jeff Niceswanger Email * jniceswa@columbus.rr.com Phone * (740) 454-8833 Vehicle Year * 1988 Vehicle Make *Chevrolet Vehicle Model * Camaro Engine Size 5.7 Request Details MUST be the original head ending in the number 083. GOOD Non rebuilt cores are requested. Can be bare, but castings must be non-modified. These are for NHRA Stock and SuperStock Classes and will be heavily modified when finished. Our shop is looking for good cores to start the process. This is the third major supplier of used cylinder heads I have asked about the 083's.Same answer. None available or they will not separate these desirable castings from the rest of the motor.
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 05-06-2023 at 07:54 AM. |
#3 | |
Liked 66 Times in 31 Posts
I have the 083 heads om my car but they have only had screw in studs, stainless valves and good springs put in them. I need to know who to send them to for stocker prep.
I doubt anyone of the big suppliers will sell you the complete engine until they have rebuilt it for sale to public. Who knows what all they have done to the heads in the process. Quite the roll of the dice.
Jeff Niceswanger 3740 SS |
Liked 48 Times in 24 Posts
Guys ; Those 083 's. also came on 1987 Camaro/ firebird 4bbl cars.
I had the car and a 2nd set of heads for yrs. Finally gave them away. My camaro also had roller lifters from the factory. yep it did. but not in the spec sheet!!
Rocketmancoatings |
The scarce heads are 87-92 Camaro and Firebird with the optional 350 cu in L-98 engine. I went to the dealer and purchased a new set in 2014. Inside the box was casting # 217. GM had replaced the 083's with 217's. Same GM part number on the box, but different casting inside the box. Real bummer when the 217's were even thinner and more scalloped than the original. If you notice in the NHRA guide the 217 is indeed listed as an option. After running thru the hoops to get the superseded pts approved and built, they only lasted a few weeks before being sent back to Rays Crack Service for leak repairs. After the 3rd repair in a couple months Ray hated to tell me a new set of 6000 dollar heads needed to be junked, but he was right. Every few runs they poked holes the size of pencil erasers in them.
Liked 166 Times in 71 Posts
You're thinking of the 081 casting 305 head, these guys are looking for the 350 version casting 083. Oddly I had an 87 cutlass with the same engine you speak of, 305 with roller cam, 081 heads, aluminum 4 bbl intake
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
