Old 05-03-2023, 09:06 PM   #1
Gmirza
Liked 253 Times in 95 Posts
Default Converter flush?
Is it possible to flush a converter without cutting it open?
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 05-03-2023, 11:49 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Converter flush?
Most Transmission repair shops have a converter flush machine. Just beware that they are meant to flush burnt oil and have trouble with gritty metal debris. If your trying to flush metal out, it is probably better to have the converter cut apart, so everything can be clean throughly, and possibly replace the bearings.
Old 05-04-2023, 09:07 AM   #3
VE6DRW
VE6DRW's Avatar
Liked 43 Times in 14 Posts
I've been looking for a shop in western Canada to flush a converter, but most have abandoned the practice. Either they install new or reconditioned convertors, or cut them apart and rebuild them.
I think it's becoming a "lost art".
VE6DRW is offline   Reply With Quote
Old 05-04-2023, 11:57 AM   #4
As Russ said, you can flush the oil out of one ,but most of the debris hides up under the weld seam at the radius high point. I doubt that will ever flush out.
If you don't have a drain plug (highly recommended) the best you can do is, first,
set the unit on the bench and slip a small vinyl hose through the hub and all the way down to the pilot area, and start a siphon going over the edge of the bench.
Once you get most of the oil out, then refill the converter with a mild solvent like mineral spirits.
If you have a trans input shaft laying around, you can then spin the turbine for a while to stir up the fluid. Siphon it out again , then blow it out with air until mostly dry.
That's about the best you can do , my friends.
Old 05-04-2023, 01:48 PM   #5
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Where in Western Canada are you? MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-04-2023, 08:43 PM   #6
Gmirza
Thanks for the replies. Unfortunately there’s more junk in there than I was hoping to find. I’ll send it back to ATI and get it done right.
George Mirza
D/SA 1236
‘71 Duster 340
Old 05-05-2023, 09:45 AM   #7
VE6DRW
VE6DRW's Avatar
Located just west of Edmonton.
Old 05-05-2023, 09:51 PM   #8
MAURICE BLENDHEIM
TCS Convertors in Langley BC, offer Convertor Servicing. MB
