Old 01-31-2023, 07:40 PM   #1
Kirk Morgan
Liked 81 Times in 45 Posts
Default 1995 Mustang Super Stocker
Iam building the 352 Cobra Jet and what is the opinion of using motor plates in this application. Pros and cons.
Thanks Kirk
Kirk Morgan is offline   Reply With Quote
Old 01-31-2023, 10:19 PM   #2
SSDiv6
Default Re: 1995 Mustang Super Stocker
Thanks Kirk
When allowed by the rules, use motor plates.
Use the centered front plate, not the offset plate.
Racecraft and ATF make a plate for either using the OEM timing cover or Jesel Belt.
They also make a plate if using the 1994-1995 timing cover, which it is different than the earlier engines.
https://www.racecraft.com/motorplates-c-284/
https://www.atfspeed.com/14-Inch-Thick_c_365.html
Old 02-01-2023, 08:00 AM   #3
427FE
427FE's Avatar
Liked 362 Times in 81 Posts
Theres no cons. You support the engine front and back which takes alot of stress off the block. Ties the front together. And with the motor mounts removed, it increases header clearance. Taking the engine in and out is easier too. You can mount things on the plate like a coil or whatever have you.
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 02-01-2023, 02:25 PM   #4
Kirk Morgan
Do they make a special starter for proper engagement to the flex plate or am i over thinking this? I would need spacers for the torque converter spacing which is no problem and i would need to recheck the driveshaft for fitment also. Anything else?
Thanks Kirk
Old 02-01-2023, 03:19 PM   #5
Hacksaw
Liked 314 Times in 177 Posts
Thanks Kirk
I would make your mid plate from 1/8" mild steel and everything should work. If you go 1/4" alum. then you need to change the snout on the convertor so it doesn't pull away too far from the pump in the trans.
Old 02-01-2023, 03:23 PM   #6
Kirk Morgan
Good idea. The engine already has a 1/16 block plate so just leave it out and add a 1/8 plate to it.
Thanks
Old 02-01-2023, 06:25 PM   #7
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
1/8" is too thick in my opinion, my Comp Engineering mid plate is the same thickness as my factory block plate. It came with a spacer to bolt behind the flex plate to.bring the trans/flexplate and started back to the original alignment. I'm gonna say its no thicker than .062.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 02-01-2023, 09:50 PM   #8
Liked 5,153 Times in 1,967 Posts
"Snouts" (hubs) on converters are changed routinely, but "long" converters are usually built by adding a button to the pilot and using spacers on the mounting tabs. This way they can be brought back to OEM stack height more easily ;-)
