Old 01-19-2023, 10:20 AM   #1
Ben Holt
Liked 113 Times in 41 Posts
Default Shop Cleanout
All parts are used in good working order. Most of them removed from running vehicles with no issues.
Pics are available. Prices do not include shipping.
Call shop. 614-471-1022
holtracecars@yahoo.com
2.) MSD Boost Controller PN 7562 $150
- No solenoids or solenoid power harness
- No dome pressure sensor
- These items easily available
3.) Big Stuff 3 Gen 3 Engine Management System $1500
- BS3-004-007
- DAI, DAE
- GM V8
- Complete harness with O2 sensor and serial COMM cable
4.) Complete Rear End Setup $1200 for all
- Competition Engineering Sheet metal Mild Steel housing
- 39 3/4" End to End
- 1/2" Pass offset
- Early Big Ford Ends
- Ladder Bar mount centers 25 3/8" $600
- Moser 35 Spline axles with bearings installed
- 4 3/4" B.C.
- Early Big Ford
- 5/8" screw in studs with lug nuts $250/pair
- Moser 35 Spline steel spool
- PN 5S9F35 $150
- Wilwood Early Big Ford Rear Brake Kit $350
5.) Aeromotive EFI Regulator -10 AN $150
6.) Aeromotive Fuel filter element for -12 AN filter 100 micron $50
7.) Autometer Sport Comp (Black) Monster recall Tach $175
8.) Autometer Sport Comp 2 5/8" Mechanical Gauges $40 each/ $100 takes them all
- 0-100 PSI Oil Pressure
- 0-35 PSI Boost
- 0-280 F Oil Temp
9.) MSD Pro Power Coil PN 8201 $100
10.) Richmond 4.56 12 Bolt 8620 Gear $150
13.) Bosch 160 lb/hr low impedance EV1 plug injectors. Set of 8 $600
14.) Billet Atomizer 225 lb/hr injectors. Set of 8 $1000
15.) Aluminum fuel cell. Black. 10 gallons. $175
- 17" x 17" x 9" tall. -10 AN dual outlet. -10 AN vent and return.
- Sender installed
19.) Axles and brakes. Need to go together because calipers brackets are installed on axles
- Strange 35 spline race axles
- for 37 5/8" end to end housing. Centered pinion
- Mopar 2.875" bearings
- 5/8" Screw in studs with lug nuts
- Strange B1704 steel brake kit for 2.875" Mopar ends $650 for both
Ben Holt is offline   Reply With Quote
