Old 12-02-2022, 04:39 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default 283 2BBL Cam selection
Can anyone shed some light on what works and what doesn't necessarily work in reference to duration and lsa in a 283 2bbl combo? Looking at the intake and carb I feel like this is something that is not going to want a lot of rpm. If that is correct I would assume a shorter lsa is required to use the available rpm range, but what range should I be looking at for in duration?
Thanks, Chris
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 12-02-2022, 04:51 PM   #2
Billy Nees
Liked 7,781 Times in 1,743 Posts
Default Re: 283 2BBL Cam selection
Well, in my 307 (roughly the same everything except stroke) it ran well with 234/236 @ .050 on a 106 lobe sep. and in at 102 with a Powerglide. With a 3 speed, I'd probably back the cam up a few. It's going to make peak power at 6000 or less.
Billy Nees 1188 STK, SS
Old 12-02-2022, 06:51 PM   #3
Chipper Chapman
Thats some good info Billy. I happen to have a cam here that was a take out from a circle track engine, and its 235/241 on a 106, so I will likely try it as a baseline knowing this.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 12-02-2022, 06:34 PM   #4
SDT1DYI
Liked 455 Times in 147 Posts
I ran a 350 ci 1970 250/224 HP 2 Barrel combo. I have a new Bullet cam sitting on the shelf at the shop if you want it.
Steve Teeter Stk/SS 620.
360 979 3126
SDT1DYI is offline   Reply With Quote
