Old 10-24-2022, 08:46 PM   #1
4speedracer
Liked 10 Times in 6 Posts
Default Holley carb question
If running a single inlet Holley carb for super stock can the fuel bowls be converted to a dual inlet?
4speedracer is offline   Reply With Quote
Old 10-24-2022, 08:52 PM   #2
SSDiv6
Default Re: Holley carb question
The carburetor must retain its original configuration.
If the original carburetor was a single inlet, it must remain a single inlet.
Old 10-24-2022, 10:40 PM   #3
mschafer
Liked 13 Times in 9 Posts
And if the carb came with a metering plate in the rear bowl you can't convert it to a metering block.
mschafer is offline   Reply With Quote
Old 10-25-2022, 08:27 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
I am pretty sure that you dont have to run the exact carb number any longer in SS. As long as it is the correct type carb and measures properly it is legal. Best to check with your tech director and get a clarification
Mike Pearson 2485 SS
Old 10-25-2022, 09:10 AM   #5
pmrphil
Liked 397 Times in 153 Posts
But there ARE metering plates that utilize normal holley jets
Phil Molski
PMR Performance
S/C 1623
Old 10-26-2022, 04:09 PM   #6
mschafer
I know that metering blocks use a jet and if the carb didn't come with one on rear bowl it will DQ the car, I witnessed the car that this happened to at US National's this year in SS.
Old 10-26-2022, 06:15 PM   #7
pmrphil
Cool Re: Holley carb question
I did say "plate", not block. It's common practice, if you have the right parts
Phil Molski
PMR Performance
S/C 1623
