What are you guy making of the rule change for the valve grind in stock eliminator? Do you think the rule was loosened enough to get creative with the valve grind and actually gain in the horsepower department?
Liked 323 Times in 63 Posts
Better wait a few days before doing your new valve job! I talked to NHRA today and they have not decided yet if we can change the valve seat angle from the stock angle.
Bob Shaw V/SA 515 |
Liked 3 Times in 1 Post
Little late for that crap, i was told a month ago how it was going to be and now it's in writing, so they need to stop changing their minds!
Woodro Josey 2002 STK |
ya'll better read that rule again my rule book says must retain stock valve angle
Sean Ward NHRA s/ss/comp#2882 SW4 MOTORSPORTS Last edited by Sean Ward; 12-12-2007 at 08:08 PM. |
#5 | |
1. They publish a draft of the new or revised rule for comment to the PUBLIC. 2. Depending on the rule, there is a commentary period that varies from 15 to 45 days. All the comments can be made via mail, fax or electronically. The comments are public and available for view by others. 3. During the review period, the government looks at all the comments; at closing, a board reviews the comments and a final draft is then release with an enforcement date. 4. When the enforcement date is due, then the new or revised rule is published as an official document. The process is easy and gives everyone an opportunity to comment. I just cannot understand why NHRA does not adopt such a process and allow those with a current competition number to comment prior to a rule issuance. |
Liked 81 Times in 35 Posts
Valve angle and valve seat angle are two seperate animals. Woodrow is right and Sean is right.
Greg |
Sean, then what does any valve job mean?
just got my book, looks like any valve job, as long as you don't go more than .250 past the seat
Chad Rhodes 2113 I/SA |
OK. Having just seen the new diagram for a legal stock valve job (that was omitted from the 2008 rule book), on page 126 of the Dec. 14 issue of ND, it appears that 'any valve job' really means the following: First, there is no indication that the number of angles has changed, still just three. Second, The part about the maximum bottom cut angle being limited to 70 degrees has been omitted. Third, an additional comment was added to the distance below the top of the seat angle being limited to .250" to stipulate that it can extend further if 'OEM'. So that's it. Looks like another classic case of a poor technical description in the rule book. If this interpretation isn't correct, then NHRA Tech is in worse shape than I thought.
Liked 279 Times in 68 Posts
The ruleboolk says any valve job allowed.
Greg |
