Liked 225 Times in 30 Posts
1-Pair 308 stock eliminator heads, fresh valve grind, new valves
66 cc, 1.88 intake valves bolt on and go. $2900.00 1-pr small block adjustable rocker arm assembly by Rockerarm Specialties, thick shafts, complete $200.00 -sold 1-pr small block thick rocker shafts. $125.00 -sold 1-New set Barton tool steel uncoated solid lifters $400.00 -sold ProTrans manual reverse valve body,fits 904 or 727 transmission $250.00 Turbo Action manual reverse valve body 904-727 $200.00 1-RB tack drive distributor Mopar perfomance $150.00 1-1964 -426 HEMI original 4bbl aluminum manifold $250.00 -sold 1-1964 - 426 Hemi original 4bbl Magnesium manifold $475.00 -sold 1-1963 # 286 Max Wedge head, 1 ONLY $500.00 1-EARLY W-2 econo head $200.00 1-used set B&E body .840 dia. Mopar Performance race torsion bars $300.00 -sold 1-New set B&E body .840 dia Mopar Performance race torsion bars $475.00 -sold ! PRO TRANS 727race trans, all aluminum inside, 2.45 ratio, no trans brake $4500.00 ! complete 440 -6pk pan to manifold stock elminator engine, fresh 0 runs. $15000.00 Lots of other parts, wheels etc. complete machine shop for sale.760-630-9094 Last edited by Gregg Luneack; 09-10-2022 at 04:06 PM. |
I will take the small block rocker arms and shafts!
Liked 140 Times in 46 Posts
I'll take the torsion bars. 33O-212-53O7.
Jon Sarrett Stock 3779 |
Liked 145 Times in 32 Posts
Gregg
When you have a moment could you call Mike Loge 925-584-8402 I'm interested in a couple items. Thank you!! Scott |
If the RB Dist. is mag pickup (Not Points) = I will take it.
Gregg was just told about this. do you still have the pro-trans trans. ?
