Liked 62 Times in 19 Posts
Am upgrading my fuel system from a stock tank in my Chevelle.Any advice appreciated.
Liked 10,758 Times in 2,236 Posts
Just because it is a AN10 fitting on the tank outlet. Make sure the hole in the fitting is the correct ID size for what ever size the AN fitting is advertised. I had to resize mine.
If you can put your car on a set of scales and move 25 to 30 lbs around to help the balance of the car with the simulated weight of fuel and fuel cell. I use a five gallon metal tank with foam in it. |
Liked 81 Times in 45 Posts
Also put weight in the drivers seat equal to your weight.
Liked 1,001 Times in 276 Posts
I like the 2.5 gallon ones on Ebay, they have 2 -10 fittings, a return, and a rollover valve. you can get them with and without foam. I know the foam can come apart from certain fuel, I just feel with a -10 return on my car, the foam will de aerate the fuel.
Duane Hoven 1342 SS/GT |
Liked 1,939 Times in 583 Posts
If your car is close on weight use a small cell. I have a 3 gallon cell in my car and usually run 2 gallons in it. I can get real close to minimum weight with a gallon. I have a Jaz plastic cell. No foam. No sense carrying more fuel than needed.
Mike Pearson 2485 SS |
Liked 147 Times in 34 Posts
I put a Rhodes 4 gal alum. no foam cell in my 68 Chevelle earlier this year. about $175 at Summit.
Liked 319 Times in 82 Posts
Thanks for all the tips....Blessings BH
Liked 2,336 Times in 464 Posts
Take the foam out!!! Bp
