Liked 99 Times in 60 Posts
Of all things, I am building a 1953 Studebaker as a hot street rod that, knowing myself, will see some track outings.
Primarily it will be parades, shows, and back roads running through the gears and showing a few youngins what Studebaker taillights look like. Nice 350 SBC, Tremec 5 speed, as must as 7000 + RPM shifts, the car will be relatively light, I estimate around 3000 with the driver. My question is, what is a good choice for clutch and flywheel?
Larry Woodfin 471W |
#2 | |
Liked 1,104 Times in 302 Posts
NHRA 6390 STK M/S 85 Mustang Last edited by Rory McNeil; 06-16-2022 at 12:11 AM. |
Liked 20 Times in 16 Posts
The sbc version of a Ram Powergrip is organic/metallic dual friction and under $400 at Summit. Its a 550hp rated dual friction with very good street manners. I currently have one on a 19lb steel flywheel behind a 600hp 355 with a 250hp plate. Nitrous hits after a slight delay, no problem dead hooking radials @ 2525lbs or spinning the Powergrip 8500+ rpm. Very happy with it for a street/strip application.
I have run full face sintered iron solid hub units on the street, worked ok but hub splines and pilot bushings wore fast and didn't like the squealing during casual engagement. The dust also caused problems with the o-rings in my hydraulic throwout bearings. The all metallic puck 650hp rated Powergrip HD has sprung hub and a marcel, but it occasionally shudders in my application when trying to feather. Grant
Grant website- http://ClutchTamer.com We make your non-adjustable clutch...ADJUSTABLE! |
