Old 05-27-2022, 12:01 AM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default VP fuel / Clutch / Bellhousing / Gauges / Seats / fuel pump
Lots of parts for sale-
SOLD-Sealed 5 gallon pail VP C-25 fuel $125
SOLD-Sealed 5 gallon pain VP C-14 Fuel $90
-Small block ford 10" Mcleod Softlok single disc clutch, setup by Hyatt, has runs on it but in great condition, disc still .360 thick, normal wear, 1 3/16-18 spline disc, 164 tooth flywheel, 28g counter balance. Total assembly weight 32lbs $800
-Lakewood bellhousing for small block ford, Jerico pattern, great condition. Includes backing plate, throw-out bearing, Lakewood fork #15525 and is in the Lakewood box. SFI tag is punched April of 2014 $375
SOLD-Moroso 20105 6 qt LS oil pan, fits 1955-1987 GM cars (except G body) 5 3/4" deep, cast aluminum, used in my camaro last fall only, like new. $300
-CSR Platinum pro Starter 100P chevy V8 153 or 168 tooth flywheel, has been rebuilt with newer powermaster solenoid, starter gear in great shape. $150
-Product engineering fuel pump and relays used $300
https://product-engr.net/collections...acing-pump-kit
-MSD ignition system- 7AL2 ignition box / two step module 8739 / Pro power coil 8201 $350
-Mr Gasket 5903 SBC 1955-91 ultra seal header gaskets, I have 4 new sets in the packaging, get all four sets for $100
-Steel driveshafts 3 1/2" diameter-
43 5/8" center of joint to joint, 1350 ends Jerico yoke $125
40 7/8" center of joint to joint, 1350 ends Jerico yoke $125
SOLD-Autometer pro-comp 2 5/8" ultra lite silver 0-1600lb electrical brake pressure gauge pn#4467, gauge was recently removed form my car works perfect, comes with gauge, wiring, sensor and carbon fiber cup mount pn#2151 $100
-Autometer gauge set- 5" pro comp II memory tach 9k rpm tach, Sport comp 2 5/8' 0-100lb mechanical oil pressure gauge / Sport comp 2 5/8" mechanical 120-240 degree water temp gauge. three gauges sold together $150
-2 JAZ plastic race seats with black covers $150
-ARC 3700 overhead pro stock 6 fused switch panel, roll bar mount $110
-Grant 15" formula GT 15" silver steering wheel with black grip, also includes IDIDIT quick release hub. $100
-Pit pal oil rack #312, 24 quart oil tray 60"x 4 3/8" $50
All items can be picked up, shipped or I can bring to Norwalk pts meet or GLSSA race in Stanton the following week.
Call, text or email for more information or pics of any of the items.
brad@zaskowskibuilders.com
(616)437-4958
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 05-27-2022, 08:07 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Default Re: VP fuel / Clutch / Bellhousing / Gauges / Seats / fuel p
Hi Brad. I am interested in the fuel pump. Can that pump be used with a carburetor?
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-27-2022, 09:31 AM   #3
dragracer502
dragracer502's Avatar
Liked 10 Times in 8 Posts
Good morning Brad, you have a PM for the C25
Thanks,
Frank
F Federico
NHRA J/SA
dragracer502 is offline   Reply With Quote
