Old 11-28-2007, 09:01 PM   #1
malibuwgn
Default Quick brake line question
My 82 Malibu wagon bone stk factory power disc brakes.Plastic resevoir on top.
Putting line lock on,and those lines disappear down between frame and stuff in and out of prop valves.
So which line on master cyl goes to front brakes? front or back one?---------------Thanks
malibuwgn is offline   Reply With Quote
Old 11-29-2007, 02:48 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: Quick brake line question
I'm 99% sure it's the front.
Old 11-29-2007, 08:12 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Bleed one of the front brakes (you're going to have to do it after the line lock install any way) and see which reservoir goes down.....That would be the one to the front brakes. I am with Greg. I bet it's the front one.
Old 11-29-2007, 11:18 AM   #4
Dave Goob Cook
Dave Goob Cook's Avatar
If I remember correctly, the front line is the 3/16", and the rear is 1/4".......
Dave Goob Cook is offline   Reply With Quote
Old 11-29-2007, 11:27 AM   #5
malibuwgn
The line on the front is definitly larger than the one on the back.
Bob,I thought about that,But I think its just 1 big reservoir that supplys both.I'll check it again---Thanks
Old 11-29-2007, 11:54 AM   #6
Harry 6674
Theres a partial divider in the reservoir to serarate front and rear. Bleed the front as was suggested. Youll see the level go down on the correct end.
Harry 6674 is offline   Reply With Quote
Old 11-29-2007, 12:45 PM   #7
Dave Goob Cook
Come to think of it, those lines may be metric on an '82, so choose your fittings carefully.
Old 11-30-2007, 02:07 AM   #8
Ken Haase
The larger brake line (front one) goes to the rear of the distribution block on the frame and then on to the rear brakes. The smaller rearmost line on the M/C goes to the front discs.
Ken Haase is offline   Reply With Quote
Old 12-02-2007, 07:12 PM   #9
malibuwgn
Thanks guys,It was the back one.After running around trying to find suitable switches and ways to mount them on other cars.I broke down and bought the Hurst switch.18 bucks with racer discount at Jegs.I highly recommend it.It has a big rubber band on it.Just take the shifter konb off,work it down over the shifter to the desired spot,screw the knob back on and your done.
