Old 12-13-2021, 06:53 PM   #1
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Default New HP posted
This just in:
2021 End of Year Stock, Super Stock Horsepower Adjustments Announced
https://www.nhraracer.com/apcm/APCMv...?a=72391&z=132
Horsepower Adjustments – From Competitor Requests
https://www.nhraracer.com/apcm/APCMv...?a=72390&z=132
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 12-13-2021, 08:00 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: New HP posted
I must have confused something. I didn't think you could apply for a
H.P. reduction if your combo had already received horsepower.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 12-13-2021, 08:34 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
J.R.
That's what I was told........hmmm must be a special case
Old 12-13-2021, 10:21 PM   #4
rboyle
rboyle's Avatar
Liked 602 Times in 165 Posts
Which combo received the refund of HP that was penalized recently? Just curious as I have no idea.
Old 12-13-2021, 10:28 PM   #5
Liked 10,964 Times in 2,260 Posts
The sad part of this is, in three engine NHRA did not follow the rules, ie. the most reduction a combo can receive on a request is 2.25% with any part of a fraction being rounded up to the next number.
Three engines with incorrect Hp reduction are
287hp x2.25%= 6.4575 rounded up to 7 hp. 287 -7 = 280 hp not the 279 hp showed.
255hp x 2.25% = 5.7375 hp rounded up to 6hp. 255 -6 =249 hp not the 245hp showed.
207hp x 2.25% = 4.6575 Hp rounded up to 5hp. 207- 5 = 202 hp not the 201 showed.
Two out of the three mistakes could be typos but not the reduction of 10 hp on the 255 hp engine with a reduction of ten hp
Like my friend Al would say “ It doesn’t cost a thing to pay attention “
A 10 hp reduction on the 255 hp engine is 3.91% reduction the largest reduction listed is 2.25%,
go figure !
Old 12-14-2021, 12:13 AM   #6
Paul Wong
Liked 419 Times in 85 Posts
A 10 hp reduction was because of a previous clerical error. Not a basic reduction in horsepower request.
Paul Wong is offline   Reply With Quote
Old 12-14-2021, 07:42 AM   #7
Glenn Briglio
go figure !
How do you get a decrease in hp when the old hp is higher than factory hp on two combo's listed?
Old 12-14-2021, 08:07 AM   #8
The AHFS is a program based on actual run data compiled from all available runs at NHRA national events. The data-based format provides the ability to calculate average performances for any class and/or engine combination in Stock and Super Stock. The trigger point for the system is 1.00-second or more under the respective index, and must be produced on two different occasions. Engine-combination averages and class averages are then computed and analyzed to determine if a change is warranted. The amount of change is calculated on a stepped percentage basis. Where applicable, adjustments will be effective for the specific car model or body style being evaluated. An automatic adjustment is instituted outside the two-time a year process when a 1.20 and under run is recorded during any NHRA event.
Does the last sentence in the above paragraph end the not in play AHFS at National Opens?
