Liked 1,471 Times in 308 Posts
I know this has been discussed many times before, but I want current,
real experience results. I was ordering a set of gears today, and I was offered lightening, Microblue coating, and Ceramic bearings($$$). It would be nice to have some real experience comments on these options. Thanks, J.R. |
#2 | |
Liked 28 Times in 15 Posts
Liked 3,251 Times in 989 Posts
Look at the videos, speed costs $, how fast do you want to go?
http://www.microblueracing.com/micro...-bearings.html
#4 | |
Liked 8,244 Times in 1,541 Posts
If you want to reduce the drag from your front spindle bearings, use the DRP Performance Low Drag Bearing Spacer and their bearings, They will not break the bank like Ceramic bearings do.
Also, when set properly, you can torque the front spindle nut in lieu of trying to find the sweet spot to put a cotter pin. After you install the DRP Low Drag Spacer, there is no drag at all when you spin the front wheels. They make the spacers for most applications and if you have a unique application, they can custom make a spacer. https://www.drpperformance.net/hub-components https://www.facebook.com/cammotorspo...8796213949255/ Interesting info on bearing drag: |
Liked 281 Times in 110 Posts
I'm doing a R&P change during the off season,and considering micro blue carrier and pinion bearing's.
So will go ahead and ask...what lubricant? and how much for 12 bolt? |
#7 | |
https://www.amsoil.com/p/severe-gear-75w-90-svg/ 5 pints |
