Old 09-22-2021, 04:15 PM   #1
e vassar
Liked 271 Times in 107 Posts
Default NHRA changes to engine BP spec 9/20/21
G.M. 05-10 Added replacement throttle body
seems a little vauge
Old 09-23-2021, 08:10 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: NHRA changes to engine BP spec 9/20/21
Vague?.
Right out of the 2010 Chevy NHRA blueprint specs.
Holley Sniper 90 mm (3.545”) Throttle Body accepted
High lighted in yellow
Adger Smith (Former SS)
Old 09-23-2021, 04:32 PM   #3
e vassar
So any car or truck mfd by GM from 2005 to 2010 can use the Holley T.B.?
Old 09-23-2021, 09:50 PM   #4
Dyno
Dyno's Avatar
Liked 692 Times in 205 Posts
If it uses a 90 mm TB.
Old 09-24-2021, 01:52 AM   #5
Adger Smith
And is listed in the specs
Looks like the Holley is an approved replacement part/throttle body
Old 09-24-2021, 11:16 AM   #6
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
This is most likely so they can run a cable driven throttle body and not a drive by wire.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 09-25-2021, 08:52 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
No. Only those engines where the replacement TB is allowed. It is a replacement for the OEM Bosch 12570790 TB in 2005-08 and the OEM Bosch 12605109 TB in 2010. The Holley part number is 860008-1.
