Old 08-21-2021, 10:16 PM   #1
Liked 10,940 Times in 2,259 Posts
Default Micro Welding of bearing shell to rod housing bore
Any ideas ?
Could it be when the combustion occurs the bearings take a hit in the middle causing the outer parts of the shell to move away from the housing just slightly and then return causing a fretting action and transfer of metal, from shell to housing bore.
Old 08-22-2021, 03:37 AM   #2
Partsguy1
Default Re: Micro Welding of bearing shell to rod housing bore
Rods out of round or inadequate bearing crush. I'm just spit balling ideas.
Partsguy1 is offline   Reply With Quote
Old 08-22-2021, 08:16 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Bearing type/part number and rod type and application?
General answer: Fit in housing bore
Pictures?
Adger Smith (Former SS)
Old 08-22-2021, 09:18 AM   #4
Manley rods, King not as bad as Clevite 77, housing bore round according to AG 300. No pictures all the evidence is gone, removed.
How is bearing crush measured and where can the specifications be found?
Oil is semi synthetic
Old 08-22-2021, 09:32 AM   #5
pmrphil
Liked 397 Times in 153 Posts
I don't know if it's correct or not, but I use a height gauge to measure each shell and to verify that the shells are square, which I've found some that are way off. I've had rods on the small end of spec as well as the big side both do it.
Phil Molski
PMR Performance
S/C 1623
Old 08-22-2021, 11:20 AM   #6
FED 387
Liked 335 Times in 182 Posts
using too thin of an oil ?---oil is not "thick" enough and not enough "pressure on the bearing" to keep the proper spacing between bearing and crank
Old 08-22-2021, 12:33 PM   #7
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Any ideas ?
Larry,
Are you saying the Micro Welding is happening near the ends of the bearing?
Stan
