So, I am just thinking out loud on this.
Since all the new Factory Cars all run aftermarket SFI versions of Chevrolet transmissions, is it time to allow them for all combinations? An argument for this would be that a stick shift car can run an aftermarket transmission. An argument against would be that it would dilute Stock/SS one more time. I'm interest to see your responses. Daren Poole-Adams Stock/SS 2007 |
#2 | |
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
My personal interest in this would be my Cobra Jet and Drag Pak projects. I look at what's out there for them and it's nothing compared to what I can get for my GM cars.
Liked 539 Times in 112 Posts
There's a perfectly good example why the Cobra Jets, Drag Paks and COPOS shouldn't have been put in Stock in the first place. GM trans in Fords and Dodges galore. Should have been S/S only. I know...I know..that horse is long out of the barn and running loose.
Jim Kaekel 3836 STK |
Liked 11 Times in 5 Posts
how about all have FORD rears.
Liked 138 Times in 51 Posts
Already allowed in SS, and aside from some optimum gear ratio choices, it would slow a lot of Stock cars down with a 9"!
LOCOMOTION Racing |
Liked 56 Times in 33 Posts
ALL of the stock elin. rules SUCK BIG TIME. Stock should be "STOCK" like in 1970-1971 !
Liked 1,032 Times in 283 Posts
Is there anything that's the same as 1970/71? Its called evolution wether it's good or not!
Duane Hoven 1342 SS/GT |
#9 | |
Liked 1,443 Times in 302 Posts
It would increase the heads up runs slightly. The good automatics are as quick as the stickshifts in most cases and some are quicker.
James Schaechter 3163 STK |
Liked 117 Times in 50 Posts
An existing transmission rule that appears to not be being enforced, is the rule stating that you have to use the clutch to change gears, and specifically banning clutchless gearboxes. I'm not gonna point fingers, but I'm seeing a lot of in-car videos of stockers clearly showing gearchanges made without touching the clutch.
