Is anyone out there using QA 1 piggy back shocks, and what do they think about them?
Liked 30 Times in 16 Posts
Haven't seen them yet, is there a schrader valve visible?
Liked 62 Times in 19 Posts
Hello all ,what is every one using instead of the stock j-nuts to mount Santhuff shocks to the GM control arms on A,F bodies?
#4 | |
https://rinehartsperformance.com/ (717) 880-6716 |
Liked 889 Times in 239 Posts
The best solution and the strongest is to install an AFCO lower mount in the control arm .
Part number A550090108X. It does require welding but it can be done on the car if you dont want to pull the arm off . I made a simple drill guide with a 1/4" hole in the middle that bolts onto the OE bolt holes . Use a 3 3/8" bimetal hole saw at low speed and you will have a perfect hole to install the mount. I actually just completed a set tonight for a Stocker. along with Global west bushings.
