Liked 43 Times in 29 Posts
Looking to purchase an electric winch to mount in an enclosed trailer to pull a 3200 lb. door car. Been looking at 12 and 120 volt units and various horsepower ratings. Not looking to break the bank and the unit will probably get minimal use.
Thanks
Mark Ruset 2048 STK |
Liked 534 Times in 143 Posts
Oh, an electric one. Can't help you with that. Sorry.
Liked 805 Times in 341 Posts
I would think 12 volt would be best, especially if your trailer already has a battery. That way no need to plug in or start the generator.
For light use I would consider the Harbor Freight units. |
Thanks I was thinking along those lines. Just not sure if the 3500 rated one will work for my application and HP rating for the motors, I've see all the way from 1.3 to 1.8 on the horsepower of the motor, also some units have steel cable and some use a fabric type rope. Just want to make a one time purchase.
After twenty years the steel cable on my winch failed. However for many years before that it had strands sticking out that could have been painful it not handled with gloves.
I replaced it with a fabric rope and I like it. |
Liked 54 Times in 27 Posts
since you are just pulling the car, you don't need a 3500 lb winch. 2500 is enough, plenty. If the cable begins to fray, replace it. When winching, have someone follow the car with wheel chocks, just in case it gets loose.
