Old 06-16-2021, 08:32 PM   #1
91mustanglx
91mustanglx's Avatar
Default What throttle stop?
Under carb? Or online with linkage?
91mustanglx is offline   Reply With Quote
Old 06-16-2021, 10:50 PM   #2
Average Joe
Liked 18 Times in 8 Posts
Default Re: What throttle stop?
Under carb. Call Gary Heuer at Number One Stop. He will get you set up.
Average Joe is offline   Reply With Quote
Old 06-17-2021, 11:21 AM   #3
91mustanglx
10-4, thank you.
Old 06-17-2021, 06:36 PM   #4
flash
Liked 6 Times in 5 Posts
One stop ! call gary
flash is offline   Reply With Quote
Old 06-18-2021, 07:35 AM   #5
Ray Gottry
Ray Gottry's Avatar
Liked 68 Times in 24 Posts
I run the under carb by Dedenbear TS1 "Bear Stop" with a simple on/off timer. They told me it would take a couple of races to get dialed in. Third pass I was 10.900! My friends were shaking their heads. My wife reminded them that I had, at the time, been racing the same car for over 30 years! It has been excellent to work with.
Now keep in mind, my combination is different. I race a 4 speed and use the stop down track after shifting to 4th gear. The only problem I have is it KILLS my MPH so I have to be confident and careful at the stripe.
A lot of friends run the One Stop. They are both good choices.
Ray Gottry is offline   Reply With Quote
Old 06-19-2021, 08:06 AM   #6
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
I personally run the Stinnett stop. It is virtually the same as the #1 Stop with a few minor differences. In fact, #1 Stop makes the Stinnett stop. But as several have already said, you can't go wrong with the #1 Stop. And you can't beat the customer service of Gary Heuer. He will always take your call, and walk you through any of your questions. Great product, great service!
sst5167 is offline   Reply With Quote
