Old 06-16-2021, 01:58 PM   #1
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
Smile Where is it legal to add ballast?
I am changing classes and need to add 100lb (ug). I will use 2, 1/2" bolts with welded nuts per the rules,
Is it legal
-to add ballast in the passenger compartment?
-to add ballast under the car?
-to add ballast in the trunk?
thanks in advance, Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 06-16-2021, 04:17 PM   #2
Hacksaw
Liked 314 Times in 177 Posts
Default Re: Where is it legal to add ballast?
All are legal, provided proper mounting. Try over top of rear as first choice.
Old 06-16-2021, 10:43 PM   #3
SSDiv6
Top of the rear will affect the dynamics of the suspension. Start adding weight a few inches in front of the rear end pinion.
Old 06-17-2021, 07:11 AM   #4
Liked 11,030 Times in 2,266 Posts
Look in class rules and general regulations in the rule book on how to add weight safely. All so talk to tech and ask if there are places where adding weight is not allowed.
Old 06-17-2021, 11:40 AM   #5
cad
cad's Avatar
Liked 93 Times in 52 Posts
Would it be legal to add it to the rear axle housing vs inside the car?
Old 06-18-2021, 08:32 AM   #6
Guess you could make the axle tubes out of thicker material.
Old 01-27-2022, 04:36 PM   #7
west coast
Liked 230 Times in 75 Posts
Best place for ballast is at the end of the track, waiting for you to it pick up.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 01-27-2022, 07:49 PM   #8
e vassar
Liked 281 Times in 110 Posts
I know this was meant in jest,but be careful folks. Awhile back D4 was checking everyone at fuel check for loose ballast inside the car. A few racers got bounced!
Old 01-26-2022, 08:20 PM   #9
mjacquesjr
General Regulations Section 21, page 19
General Regulations
Requirements) is permitted. Removable weight must be securely
mounted to the frame or frame structure by a minimum of two
1/2-inch-diameter steel bolts per 100 pounds, or one 3/8-inch
steel bolt per 5 pounds; all other weight bars, pucks, etc. must
use minimum 1/2-inch-diameter SAE grade 8 bolts for attachment.
Hose clamps, wire, strapping, tape, tie wraps, etc. for securing
weight or ballast prohibited. Acceptable forms of ballast are 1)
Heavier gauge steel floors (i.e., 16- or 18-gauge, heavier gauge
and/or plate steel prohibited); 2) Frame reinforcing cross members;
or 3) the addition of protective equipment such as roll bars,
flywheel shield, etc. If additional ballast is needed and is permitted
by Class Requirements, it must be permanently attached to frame,
bolted with two 1/2-inch-diameter bolts per 100 pounds, with nuts
welded to bolts. Maximum amount of removable and/or permanent
ballast, unless otherwise stated under Class Requirements, is 500
pounds. Cars running 8.49 and quicker are limited to 250 pounds
maximum, per SFI chassis specification.
mjacquesjr is offline   Reply With Quote
Old 01-26-2022, 09:37 PM   #10
Chevy55
Banned
Liked 179 Times in 89 Posts
My suggestion would be if you have access to 4 corner scales see which corner of the car needs the weight.
Chevy55 is offline   Reply With Quote
