Liked 520 Times in 132 Posts
What are the options in adjusting ride height on a ladder bar car. I changed shocks (same length) but my car sits 1 1/2 lower in the rear than before. Nothing else was changed.
Ed Carpenter 66 Chevy II 4244 SS/I |
Liked 888 Times in 239 Posts
Ed, You didn't mention if you used the same springs ,or replaced them? ....Possibly a different rate spring than previously on the car? ..... Also, did you check the spring platform height? Most shocks have at least 1 1/2 to 2" adjustment there, Altho that should only be used to set the loaded length of the shock,cranking it too far will cause suspension travel issues...... I would remove one of the new shocks for a closer side by side comparison to one of the old shocks ..........Tom
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 11-16-2007 at 06:48 PM. |
