Old 06-08-2021, 02:14 PM   #1
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
Default What is best portable canopy?
I am not looking forward to the heat of summer. I would like a way to at least partially keep the car out of the sun. What products have you guys had good luck with? Here are some of the things I have heard are important.
-ease of setup, ease of tear down
-ability to stay in place in the wind
-what size to use, is 10x10 to small?
thanks in advance, Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 06-08-2021, 03:37 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: What is best portable canopy?
if you look around you can usually find at the Big Box stores inexpensive ones (NOT CHEAP BUT LOW COST) or online but figure in shipping if you go online--- Expect to spend about on average in the $100-130 range for a 10x10 and they go up from there- DO NOT get a anything smaller than 10x10 it gets too crowed and some cars are too wide to fit underneath them -whatever you get make sure that the "ribs" that hold the roof area up are metal tubing not the fiberglass rods that the real cheapies have---also invest in some bungee cords or cheap ratcheting straps to anchor the corners down if it gets breezy along with some weights to attach those cords to---Obviously EZ UP is the Cadillac of them all but probably the most expensive watch out for the Walmart units some models are not worth it too many problems(JUNK)---lesser priced units are available and will do a good job---I suggest if it is in your budget buy 2 canopies that way you can move them about if need be to cover the whole car and provide shade for the troops too---Suggest WHITE as any of the others (RED, BLUE) will make everything under neath have a bluish or red tint to it-- thats my experience----FED387
Old 06-08-2021, 04:21 PM   #3
HR9121
HR9121's Avatar
I highly recommend spending the extra money for one of the EZ UP canopies. They are a little pricey but I have the 10x20 that I've had for 6 or 7 years and it's still in great shape. It's a little on the heavy side but I can put it by myself but definitely works easier with 2 people. Just like everything else we do spend a little more now but save a bunch in the long run.
James Williamson
W200 J/SA. SS/JA
Old 06-08-2021, 05:14 PM   #4
65signet
Liked 49 Times in 22 Posts
I have the best luck with Summit brand canopy, it has lasted longer that any of the others, and you cant beat the price.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 06-08-2021, 05:28 PM   #5
JGrossijr
JGrossijr's Avatar
Liked 463 Times in 60 Posts
There are several brands that are good. I think it's more about the features and construction.
Important construction/features in my opinion are
- Aluminum frame - for lower weight
- Vertical legs - So shade coverage is as big as the footprint
- Full truss construction - This is a must for strength & durability
- Spring pull pins - Easy to operate and replace if necessary
- Vented top - Less likely to fly away in a gust of wind
I've been happy with the Caravan brand Aluma model. Own several of them
JGrossijr is offline   Reply With Quote
Old 06-08-2021, 07:01 PM   #6
FED 387
Also some offer a white powder coated frame nice extra touch but not necessary--- ditto on what the others said 10x20 can be kind of cumbersome but if you have a few guys its easy to put up--just noticed that EZ UP has some sales going now depending on the retailer--FED 387
Old 06-09-2021, 12:52 PM   #7
dragracerray
Thanks so much for the suggestions. Lots of good advice. I have never owned a canopy before. This is a big help. Ray
Ray Bassett
