Liked 602 Times in 165 Posts
Is the 327/300 hp combo good? Does anyone make a good carb for this setup?
Who makes a 12 bolt rear setup for the Corvette IRS rear? Just investigating at this moment. Any and all advice is appreciated on this combo/car set up. Thanks. Rich Boyle |
Liked 328 Times in 80 Posts
If I was building one, I think I would go with 66-67 Holley vs the 65 AFB. The HP factor is 5 less with automatic transmission. The quick fuel carb is pretty good. The secondary throttle plates are a little larger in the AFB, but is lacking elsewhere. Just something else you might want to investigate before hand.
I think Stephen Belanger has run the AFB some on his Chevy II. Ernie Neal SS 354 Last edited by Ernie Neal; 04-02-2021 at 10:25 PM. Reason: correction on factors |
Liked 19 Times in 9 Posts
Why use an IRS rear, if you can run a solid axle? Seems as though the solid axle would be more efficient and weigh less with fewer parts to break. Also, would save a lot of money.
I'm wondering if there is a bolt in solid axle available. That way you could save the stock IRS for later. Seems like I've seen an A/S or B/S with a solid. Hard to imagine a 700 HP motor not destroying almost any IRS. Loren |
If it came with a powerglide can you change it to a 3 speed automatic? I heard mixed answers on this.
Liked 8,220 Times in 1,538 Posts
Liked 128 Times in 50 Posts
Hammerhead IRS makes a Corvette IRS that can handle more than what a Stocker can put out.
Bobby Lundholm 3516 G/SA |
Liked 472 Times in 72 Posts
Cool car alert!!!
