Liked 6 Times in 2 Posts
and allegedly, the requirement for cars running 7.50 - 9.99 to have one has been dropped. Anyone else heard, or know if this if factual ??
you better get one you do have to have one
Sean Ward NHRA s/ss/comp#2882 SW4 MOTORSPORTS |
I sure hope so. I would think it will cause excessive engine heat and build heat very quickly. Not good in the Southwest.
Where did you read this? |
Liked 8 Times in 1 Post
we (Super Stock) have another year until we have to have them. I will wait to the very last minute until I get one. I learned my lesson with the muffler farce. BTW would anyone be interested in a high quality pair of mufflers from Dawson. Never been used.
Liked 21 Times in 6 Posts
Hi this Dennis Ridgeway from DRE Engine Diapers the last I have heard is super cat. this year then S/S next .There is some confusion on spec you will only need a NHRA accepted diaper not a SFI 7.2 if you have ? call or post ? this is not a ad it is information
If they do mandate diapers in the Stock/SS classes it is just another example how NHRA is displaying their lack of knowlege when it comes to our classes. How would we be able to adjust oil levels during a weekend. Testing would be an absolute nightmare. I know DRE is a sponsor of this site but I am tired of hearing them push for something that would be so bad for out classes.
I'm sure it can be done...and I'm also sure that there are more complicatied applications of a diaper than mine....but it will be exciting to see a diaper on a stock front end of a Pontiac Firebird like my '72.
I have a concern for myself and the person in the lane next to me should a problem should come up but I also have a concern that the diaper will retain heat and cause premature failures and even a fire should the engine let go. Recing in the Southwest in the summer can be cruel to everyone and everything. |
between my header and oil filter 1/2 inch of clearence, on the front of motor 1/4 inch between the crossmember and oil pan the drag link runs right underneath the front of the pan and is so tight if i put a grease zerk in the tie rod end it hits the pan. now how in the H----- am i supposed to put a diaper on that
and by the way its a 72 gto with 20k original miles cutting the crossmember is out of the question
Jeff Essmann 5780 ss/ja WEB SITE WITH MY RACECAR |
