Liked 3,226 Times in 981 Posts
Liked 8,114 Times in 1,531 Posts
Damn !!!!!!!!! .....happy holidays. !!!!!!
Liked 3 Times in 1 Post
Be sure to check the classification guides and engine blueprint specs too. There are changes that were not posted there as well. For example, 1987 Chevy Camaro 305 190 combo went from 240hp to 245hp and engine specs changed from flat hydraulic to hydraulic roller.,
#4 | |
Liked 372 Times in 130 Posts
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 12-18-2020 at 03:09 PM. |
Liked 478 Times in 91 Posts
Am I reading this correct.....
2011-2014 Mustang Combo with 26 hp off?
Austin Williams 3 SG 464Q STK SC |
Liked 534 Times in 143 Posts
Liked 109 Times in 32 Posts
According to the rule book, once an engine family receives a hp increase, it is never eligible for a hp decrease.
Stock had 7 combinations get a reduction. 3 of those combos had an NHRA hp rating higher than the OEM rating: 1977 Malibu: OEM = 160-170, Old = 275, New = 271 1969 Roadrunner: OEM = 390, Old = 400, New = 395 1986 T'bird OEM = 150, Old = 200, New = 197 How were these eligible for a reduction?
Drew Whalen Stk 3186 |
Liked 254 Times in 78 Posts
I was told by Pat C that if the NHRA HP was less than the factory hp it could be considered for a reduction. Most of the reductions fit that, but not all. Curious.Also, the 76 and 77 305 novas both got hit, but only the 77 had runs to cause the hit. They didn't do that to the 302 FFFFords 75-78.
Mike Moller NHRA 203 Q-R-T/SA Last edited by MikeMoller; 12-20-2020 at 12:51 PM. |
Liked 319 Times in 68 Posts
[QUOTE=rtaylor3410;630071]Be sure to check the classification guides and engine blueprint specs too. There are changes that were not posted there as well. For example, 1987 Chevy Camaro 305 190 combo went from 240hp to 245hp and engine specs changed from flat hydraulic to hydraulic roller
Lee Valentine 1661 STK |
#10 | |
