Liked 99 Times in 60 Posts
My 3rd gen Camaro Lamplighter project is equipped with an Ed Quay, unequal length, four-link system, and rear frame. It is a back half build the OE front suspension and Randy Mans front struts.
The question, up to recently adding an anti-roll rear bar, has been the standard thinking. However, there has been some suggestion that the unequal length bars work better without the anti-roll. For those racing with the Ed Quay back half, what is your feedback about the anti-roll bar?
Larry Woodfin 471W |
Liked 704 Times in 281 Posts
My Monte was built by Ed in 1985 and my experience was the opposite. It was an unequal 4 link. I struggled to get car from not rolling over. With anti bar it solved roll over, but cant say it was faster.
Liked 31 Times in 7 Posts
My car is a Quay car and I had an anti-roll installed to stop the body from rolling so bad. I have had zero issues with mine.
Liked 189 Times in 48 Posts
Do you have access to scales?
My first GT car was a Quay car. I was able to correct that tendency w/o a anti-roll system with more preload in the right top bar and a little extra height (3/4") on the driver side front spring. That being said - there's nothing wrong with an anti-roll system. Also - downward (nose down) rake on both bars (top and bottom) helps to limit the amount of roll.
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA Last edited by Angelo DiTocco; 11-09-2020 at 03:10 PM. |
#5 | |
Liked 125 Times in 59 Posts
Larry this may seem crazy to you but it really helped mine. Once I got to 5.60s it was a hand full. Just an option to keep in mind.
Curtis, I like that, a good idea and easily done. Do you also employ an anti-roll bar?
