Liked 598 Times in 164 Posts
Is it legal to remove them and any tips on how to on a 1973 Nova?
TIA Already gave up. Last edited by rboyle; 10-15-2020 at 10:07 AM. |
#2 | |
Liked 5,147 Times in 1,964 Posts
However , seeing there's no tech, it's not enforced anymore. PM me and I'll tell you how I would do it on a '73 Nova bracket car ;-)
Liked 2 Times in 2 Posts
Not legal but on our '87 Grand Prix bracket car, I chopped off both ends at the welds with a cutoff wheel, (After cutting out most of the inner door panel to make room). It wasn't easy but damn, they sure are HEAVY!
dev0 |
Liked 672 Times in 202 Posts
Mine were easy because we made sheet metal door panels, as Devo said you will be amazed how much they way. My Nova was a bracket car and weighed 2520 minus driver with sbc aluminum heads.
Liked 323 Times in 63 Posts
I would never take the crash bar out of the driver's door.
Bob Shaw V/SA 515 |
Liked 285 Times in 87 Posts
I've done it several times over the years (before plasma cutters). It takes 2 people, one that is good with a torch and a good helper. Fill a large cooler with ice and water, soak a large heavy bath towel in the cooler, wet the inside of the door. Fold and place the cold soaked towel on the outside of the door skin in the area of the cut, quickly cut from the top down with a torch. If it doesn't completely cut on the first attempt, move to the other door. DO NOT COOL THE WARM PANEL IF FIRST ATTEMPT FAILS, the door may shrink and distort panel. Be patient and restart procedure once the door cools naturally. Try this on a junk door first to see how things work, if you can. The object is to keep the door skin COLD while cutting. I have done this on several finished cars to help trim some weight, to compensate for the owners "Second Cheeseburger Syndrome". Hope this Successful Method helps...MB.
#8 | |
I would say I'm qualified to use a torch, after 50 years. You're talking to a guy that cuts pressed on bearings with a torch, without damaging the under surface.
Liked 253 Times in 95 Posts
I’ve heard of guys removing the door skin, cutting the bars out and putting on a new skin. They didn’t start putting them in the doors until around 1973, mopars anyway. I doubt you can get the old door skins anymore.
George Mirza D/SA 1236 ‘71 Duster 340 |
Liked 1,110 Times in 304 Posts
I have to wonder if tech has ever requested a door panel be removed to check to ensure any crash bars are still intact? IF one was to attempt to remove said bars, without damaging the paint on the doors ,( of a bracket car, of course!), a cutoff wheel on a die grinder would be a good way to do it.
