Sc dragster electric stop turning it on at .100, how fast can you turn it on before it effects reaction time?
Liked 4 Times in 4 Posts
Following. I turn on at .05 and shift at .05 in Super Street and I’ve wondered the same thing.
Liked 398 Times in 153 Posts
A lot depends on how high you leave, if you're on a chip or converter, hardtail or suspended, and gearing. Test, test, test.
Phil Molski PMR Performance S/C 1623 |
#4 | |
Liked 327 Times in 87 Posts
Fwiw max speed TS leave 5k, hard tail 4:30 and I just tickle the stage bulb. 1 thing I don’t like about the electric TS is you can’t adjust the on off speed. I gotta imagine that make a difference how soon you can turn it on. Last edited by J&S Racing; 11-07-2020 at 10:34 AM. Reason: Add info |
#5 | |
Liked 431 Times in 224 Posts
Electric is my preference although I do have CO2 on the dragster, with no flow control valves. I didn’t play around with turning the throttle stop on at various increments, but I did have trouble on the tree turning it on at .010 so I went to 0.100 and it was good.
S/ST 51 S/C 53 |
[QUOTE=Lenny5160;627477]My personal opinion is that the difference there is far overblown.
This may be true with a under carb style stop but the Max speed is a different animal. |
#7 | |
In a typical baseplate application, especially with most people coming off the stop in high gear, I wouldn't hesitate to use an electric stop.
S/ST 51 S/C 53 |
