Liked 14 Times in 7 Posts
I've never seen this mentioned before, When you set your timing on your crank trigger then set the distributer on number one plug how far can you advance or retard the crank trigger before you have adjust the distributer again ? Or you must adjust the distributer every time ? Thanks< By the way I'm not talking big changes just 2 or 4 Degrees
Liked 3,192 Times in 975 Posts
If you move it over 2 degrees I believe you need to check rotor phasing. I’ve got a complete tutorial somewhere and will find it if needed.
