Old 10-03-2020, 07:48 AM   #1
SST159
Liked 20 Times in 16 Posts
Default Trailer tires
Time to replace my trailer tires. Any suggestions on tire brand without breaking the bank. Also knowing the life is only 6-7 years. My current tires are Hercules Power STR ST225/75 R15 Load range E. Starting to crack between the treads now which they are 7 years old. Trailer weight loaded is approx. 10K lbs. Thanks in advance for opinions.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 10-03-2020, 08:38 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,229 Times in 982 Posts
Default Re: Trailer tires
Had a lot of trouble with Goodyear Marathons but tried their newer Endurance tires on my trailer. 10K miles and they still look great; no bulging sidewalls and with a higher load range than the Marathon I think it's a good economical tire. If you want better then you probably need to switch over to the 16" combinations. BTW, unless they are babied and keep out of sunlight most of their lives 5 year replacement is recommended.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-03-2020, 10:53 AM   #3
340Cuda
Liked 805 Times in 341 Posts
Like Jim and many others I have had troubles with Goodyear trailer tires in the past.
However I have not heard anything bad about the new Goodyear trailer tires and they have been out for a while now.
I don't think I have ever had a trailer tire blow out that was less than three years old, except for the earlier Goodyears.
Old 10-03-2020, 07:22 PM   #4
Painter
Liked 162 Times in 45 Posts
There are now load range “f” tires available. They are a very heavy and look like trailer tires. Call Greg Luben at L&S Trailers in Hawthorne Fl.
Painter is offline   Reply With Quote
Old 10-03-2020, 08:27 PM   #5
BILL TAYLOR
Liked 200 Times in 62 Posts
My tire guy told me that the Carlisles were real good again. He's never steered me wrong so I tried them 2 years ago and he was right. No issues yet in about 5K miles, they still look new!
BILL TAYLOR is offline   Reply With Quote
Old 10-04-2020, 04:29 PM   #6
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Don’t waste your money, go to 16” wheels. Way more options for tires.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
