Liked 93 Times in 52 Posts
Hi,
I picked up a 2002 39' GR gooseneck. Is Gold Rush the only place to buy these flush, recessed anchors? http://www.goldrushinc.com/images/st...rts/dring3.jpg Thank you, Clark |
Liked 43 Times in 29 Posts
I just GOOGLED flush mounted D rings and came up with numerous types. I'm sure you can find one that will work for you.
Mark Ruset 2048 STK |
Liked 335 Times in 182 Posts
NO--it looks like they took a conventional D ring and installed it from the underneath instead of from the top---makes for a cleaner look that way
#5 | |
Liked 72 Times in 36 Posts
Thanks. The GR undermount/recessed d-rings are $33 each.
CAD I changed out all 5 of mine including the one for the Winch Pulley I also noticed the Tie Down Straps were cutting into the Tie Down Eyes and I took a rotary file and lightly chamfered the hooks on tie downs hopefully that will fix the problem. Kenney
