Liked 354 Times in 79 Posts
For Sale Jeff Taylor 1967-1970 Super Stock 350 295-300/313 HP
$11,500 Carb to Pan GM Bowtie Block 4 bolt mains Cam tunnel with Roller bearings 50mm Comp Cam 904 Lifters Small Journal Manley Rods Diamond 3 ring pistons 041x Heads up cylinder heads reworked by Voges. Ferrea hollow stem valves. Manley springs. Jesel Rocker Arms Heads up Edelbrock intake Larry Stewart oil pump Custom DEEP Aluminum oil pan with draglink through design. (1st Gen Camaro) SP (Scott Perkins) Edelbrock replacement Quadrajet. MSD Crank trigger Jesel Belt Drive Dyno Sheets available! Call Jeremy Duncan at 502-817-40 |
Liked 212 Times in 64 Posts
Is this still available? Missing a couple digits for the phone number listed.
502-817-4067
