Old 04-13-2020, 06:04 PM   #1
Dissident
Liked 73 Times in 36 Posts
Default Stock Eliminator Cylinder Heads
I was surprised to see the thread that mentioned lawsuit(s) over cylinder heads and thought about posing some comments perhaps as a point that some might have opinions about. The following are some of those thoughts:
Caveat: The comments here are not intended to cause problems but to perhaps help clarify some points, not ruffle feathers. I know what the rulebook states and I have seen and tested many heads that were passed as legal. That term is interesting to say the least.
Stock Eliminator Cylinder Head Preparation
Current rules both written and what is visually allowed in Stock Eliminator drag racing is somewhat nefarious relative to practical applications. Each year some nuance is brought forward that had been not allowable in previous years. In order to have a competitive cylinder head package for a given engine, careful preparation is required.
Cylinder Head Preparation Points and Comments
1) Clean and inspect cylinder head castings (Magnaflux for cracks)
2) Prep guides / bronze liners / hone to fit stem sizing
3) Measure ports for CC volume – record notes – casting number verification
4) Prep ports and flow test / Record for File
5) Cut valve seats / Face valves to match as required
6) Measure combustion chamber CC volume
7) Disguise port work with chemical etching / ABS Cheating Bastard Blaster / or equal
8) Flow test and verify final port volume requirement
9) Cut deck surface for final combustion chamber CC requirement
10) Install screw in studs if necessary
11) Mill head bolt pads compatible and perpendicular with cylinder head deck surface
12) Finish for seals / spring seats / cups
13) Cut intake manifold mounting surface appropriate for deck surface removal
14) Note for distributor spacers and gaskets if required
15) Mark with SN and Flow File Documentation
16) Hope for accurate feedback from Customer or engine builder
Does this follow with your experiences ? What say y'all?
Regards.
HB2
Dissident
Dissident is offline   Reply With Quote
Old 04-13-2020, 06:20 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Stock Eliminator Cylinder Heads
I feel any comment on this subject could endanger or cause harm to the said lawsuit. The last thing I would want to happen in a lawsuit is it be decided by being discussed in the forum of public opinion.
I'm sure we will have plenty of time to discuss and cuss it when it is settled.
Adger Smith
Adger Smith (Former SS)
Old 04-14-2020, 11:56 AM   #3
Nmbr1GMfan
Apparently #7 is why we're so damn slow!
Todd Greene
Old 04-14-2020, 12:20 PM   #4
Jim Hanig
Liked 99 Times in 49 Posts
my experience has been that if you don't do what the fast guys are doing your not going to be nearly as fast. The rules are pretty gray as to what you can do to the heads and intake. No grind marks and rite cc in the runners your good to go.Unless you run into Westly or Wayne then you mite have a problem, of course the cost of the heads ,manifold is now in the 5500 dollar range. Then there are some combo that are still soft,You just need to pick the rite one and get your check book out. Or be prepared for a uphill battle, ask anyone who has been doing it for many years.
Old 04-14-2020, 01:33 PM   #5
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
What STK combo(s) are the heads and manifold $5500? I am assuming at that cost they are built up and installed, correct?
Andy Friar
Andy Friar is offline   Reply With Quote
Old 04-14-2020, 02:34 PM   #6
SSDiv6
The big issue is with Super Stock cylinder heads were rules have been more open than Stock Eliminator cylinder heads.
The fact that intake adapters and spacer were prohibited in Super Stock when welded, epoxied and sheet metal intake manifolds are allowed did not make any sense.
As regards to the high cost of competitive Stock Eliminator heads and intake manifolds, you are paying for the knowledge and hard work of those that build them and the cost is for a set of heads and intake ready for use.
Old 04-14-2020, 07:07 PM   #7
Alan Nyhus
Liked 800 Times in 237 Posts
A very well done set of SBC Stock Eliminator heads that perform and pass tech are easily $4,500. An intake done to match can be $1000-1500. -Al
"That'll never work....."
Old 04-15-2020, 02:56 PM   #8
Jim Hanig
Not likely.
Old 04-14-2020, 02:40 PM   #9
SSDiv6
Jim's statement is right on the money!
Classes such early Chevy small and big block, Mopar small and big block and a few others, in order to be competitive, you have to pay for the technology.
These engine packages have been in competition for decades and almost every single ounce of power has been extracted throughout the years. What makes the difference is the shop that either builds the cylinder heads and intake package and/or the engine and the camshaft design.
Old 04-14-2020, 05:33 PM   #10
Dissident
Gentle Folks of the Class Racer Forum,
When I originally posted the outline of assumptions of preparations, it was specifically intended to address Stock Eliminator heads only. The SS stuff is another stack of candle wax entirely.
This was intended as a separate issue of discussion from whatever the details are in any sort of lawsuit stuff as I know nothing whatsoever about that deal. Most of those kinds of things are settled on courthouse steps anyway.
My comments were and are that I do not do work on cylinder heads, only having seen and flow tested some. I am an old guy and have seen the allowable "modifications" become rampant and are typically passed or failed on "visual" approval or disapproval. Regardless of what the rule book states. I abhor the politics and would prefer to stick to the technical side of the equation. Unfortunately that involves people and that is the most difficult item to balance in the equation.
In the meantime of lots of us can perhaps have a sensible discussion on the Stock Eliminator issue as presented. Thank you for your participation.
$5500???? Wow that came as an eye opener
Regards,
HB2
Dissident
