Old 03-24-2020, 09:03 PM   #1
Dick Butler
Liked 32 Times in 19 Posts
Default motor Home power
Looking at used Motor Home with V10 Ford. Noticed at least 1 or two identical on several ots traded at low mileage. Why ? could it be weak motor versus diesel? Any body
comment on v 10 power in 30 ft Motor Home?
Old 03-24-2020, 10:41 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: motor Home power
Foots to the floor so much of the time. Terrible gas mileage. Working motor that had just gets worn out. Diesel may be more cost in maintenance and fuel but better diesel mileage makes up for that part.
Old 03-25-2020, 05:45 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
On a Ford V10 F53 chassis you’re essentially sitting above the motor which makes the noise such that it’s harder to have conversations. Lots of RPM too compared to diesel plus most pushers have air suspension supplementing their springs to soften the ride. Dramatically higher maintenance costs can be partially offset by getting side radiator so you can do much of it yourself. Big advantage of the diesel is engine brakes, with a good two stage brake you’ll barely use the brake on those long downhill stretches.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-25-2020, 06:10 AM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Power is ok. Got a 27 mh with the V10 and 6spd auto.Pulling a 24 ft enclosed weighing approx 8000 lbs I get 9mpg.Tow at 65 to 70mph.
Old 03-25-2020, 08:07 AM   #5
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
It's all about what you are going to pull - we have used coaches to tow various trailer's from open to low profile stacker's - we have used Class C to Diesel Pushers but what you tow is the BIG FACTOR a Class A gas coach is normally only capable of towing 5,000 lbs legal so if you have an open trailer and a door car you would probably be ok with a Gas Class A as long as your travel route doesn't take you through the mountains if so then all bet's are off we have a 6 mile hill in route to a track that we race at and with that combo you will be in the far right lane before you reach the top - just my $.02 from my experience hope this may be of some use - Bob
BA1927 is online now   Reply With Quote
Old 03-25-2020, 03:18 PM   #6
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
I am very satisfied with my 2018 F53 V10 motorhome, I previously had a 1999 V10 in a Class C E450 chassis. The 2018 pulls the trailer effortlessly. Like what was said , it all depends on your total weight. For me I couldn't be anymore happier.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 03-25-2020, 07:50 PM   #7
jimmyparker
Liked 309 Times in 88 Posts
Ultra Rv has programs for 3 valve V-10's that helps to the tune of 50hp and 50 foot pounds of torque and helps some with the down shifting problems. They cost $495 but each one is tailored to your RV, they send you a hand held device to pull your strategy code, you ship it back and in a few days you get it back with the new program. You can tell the difference backing it out of the driveway!
jimmyparker is offline   Reply With Quote
Old 03-26-2020, 08:42 AM   #8
James Perrone
Liked 1,846 Times in 431 Posts
I have been towing with a v10. 33 ft Rv for 15 years
First one 2002 brand new. What a dog. But it served its purpose was good to me.
Traded up to a 2011 Thor v10. What a difference. Way more power better stopping
Oh course you have to run up a hill. foot to floor but it does a good job.
Don’t by new rv. Buy used it’s a much better deal bugs worked out
james perrone 1290 STK
