Liked 10 Times in 5 Posts
All items + shipping
PMS-Bellhousing Indexing fixture/no indicator $15 Rod bolt stretch gauge, w/metal frame & strong spring in indicator. I think, it is an ARP $75 Cam checking tool-.fits .842 & .875 bores, w/tool for flat or roller tappets, w/indicator(missing glass) $60 BHJ-BBC valve depth checking bar(I think it has been discontinued by BHJ) $20 MANLEY- Lash cap puller-$20 Assortment of Jesel & T&D shims, hold down bolts, etc(mostly Jesel, NO rockers)+2 different valve spring replacement tools for shaft rockers.(Similar to Powerhouse #351035) $75 Edelbrock Torker #2725 w/frt oil fill hole, used very little, all surfaces good. $50 ACCELL BEI, pt #35100T Chev. distributor, w/3 ignition boxes, tach drive $100 SUN Electric LVT-33 leak down/vacuum tester $75 Tapered ring installers, B&B 4.600 w/step to use with o-rings $30 ARP 4.125 w/step to use with o-rings $30 Childs & Albert 4.560 w/step to use with o-rings $30 Generic (no brand name) No step 4.530 $25 4.500 $25 Call, text or email for pics & info 317-442-5938 vicholley4@yahoo.com Last edited by vholley; 03-22-2020 at 01:13 PM. Reason: Mark sold |
Liked 205 Times in 93 Posts
pm sent, thankyou.
Liked 708 Times in 285 Posts
PM sent thanks
Liked 13 Times in 7 Posts
Can I get a picture of this,,,, Precision Measurement Supply-Flow Bench Valve opening fixture w/indicator $75
Thanks, Ron |
Thanks Vic. received package today. Jeff
