I need a set of park lamps and grilles. Thanks, Bob Fowkes 3600 h/sa
Liked 8,127 Times in 1,534 Posts
Good luck, as far as I know...no company reproduces the grill inserts. Because of their age, the original grill inserts will break if you look at them wrong....The Z 28 grill inserts are available but they won’t fit . I actually made the grill inserts myself .....
Liked 11 Times in 6 Posts
I bought the Z28 inserts and cut about 3/4 " out of them to make them fit.
CJ McDonald I/SA 2564 |
Thank you. I will do something
Liked 427 Times in 97 Posts
The aftermarket Z-28 Grille Inserts will work as long as you do a little massaging, and are carefull installing them
Liked 333 Times in 180 Posts
schipsoft.com---$99 per pair---REPROS not OEM but will work--FED387
Liked 34 Times in 12 Posts
They were available on ebay at one time. A guy was 3d printing them. Took some primer to make them smooth but they worked.
