Liked 68 Times in 22 Posts
Is it legal to run a regular old style Chevy block rather than a LT1 block in a 98 Camaro in stock eliminator ?
Liked 79 Times in 22 Posts
Yes, as long as the main bearing size is the same. In other words, you can't run the small main journal Chevy pre-1968 block.
The blocks are NOT a direct replacement. The LT block has a completely different cooling routing system, unique front drive distributor, different timing cover, etc. Others have converted an LT engine to a earlier generation block, but it's not that easy. |
Liked 691 Times in 205 Posts
Maybe in Superstock, but in stock you must use the Opti-spark, which requires the LT1 block.
Liked 109 Times in 32 Posts
MSD and stock GM Opti-spark's will work the traditional style sbc blocks.
Drew Whalen Stk 3186 |
Liked 239 Times in 114 Posts
Standard sbc water pump with spacers to clear distributor. Water flow can be either direction, these motors don't see enough temperature to need the reverse cooling.
Drew Whalen Stk 3186 Last edited by Whalen3186; 10-10-2019 at 11:44 AM. |
