Old 09-24-2019, 11:32 AM   #1
joespanova
Liked 13 Times in 11 Posts
Default Thunderbolt weight
If I read correctly , an A car in S.S. carries 6lbs / hp. So the factory "rated" the 427 ( was that a tunnel port?) at 425 hp? So Paquet's car only carries 2550 / 2600 lbs?
http://www.classracerinfo.com/NHRA_Classes.aspx
or:
http://classracer.com/classes.html
so is it LBS / hp or LBS / cid?
Old 09-24-2019, 11:56 AM   #2
troublemaker427
troublemaker427's Avatar
Liked 64 Times in 23 Posts
Default Re: Thunderbolt weight
Hi Riser, not a Tunnel Port
Jody Aberts
Troublemaker2
1966 Fairlane 427
Old 09-24-2019, 12:08 PM   #3
joespanova
OK , and..........
I wanted the weight confirmation....? Am I close ?
Old 09-24-2019, 12:25 PM   #4
Nick Heath
Liked 576 Times in 137 Posts
Super Stock factor for the T-Bolt is 466 (or 482 with replacement heads).
466x6.00 + 170 = 2966# or 3062# with replacement heads.
Old 09-24-2019, 12:45 PM   #5
joespanova
So at some point they added the 170......
Thanks
Old 09-24-2019, 01:05 PM   #6
JeremyDuncan
Liked 355 Times in 80 Posts
Wink Re: Thunderbolt weight
170 lbs is added for drivers weight
JeremyDuncan is offline   Reply With Quote
