Old 09-02-2019, 09:38 PM   #1
Btp 2332
Btp 2332's Avatar
Liked 5 Times in 1 Post
Default Late model consistency?
I enjoy jumping into bracket racing mostly in the sportsman classes or no box in my 2012 Dodge Challenger 5.7. Is anybody having success with late model cars being consistent? I try to heat soak and keep the car hot before each pass but it’s still moving the dial around 2-500ths. Car has headers, 3800 stall, 4.30 gears, drag radials and skinnies. Usually the 60ft is very close but around the 330 it’s moving around. Any input would be great.
2012 Dodge Challenger RT 392 stroker. 10.36@130
Btp 2332 is offline   Reply With Quote
Old 09-03-2019, 08:03 AM   #2
Keith 944
Keith 944's Avatar
Default Re: Late model consistency?
Not sure how these cars are set up from the factory but a problem I see is the throttle /drive by wire. Although you said the 60 is consistent still could be a problem with reactions and et. I could feel the delay sometimes in a vehicle I had with it. I think they make something to be able to correct it. I still prefer a solid connection from pedal to linkage. Then there’s all the other electronics to deal with.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 09-03-2019, 10:27 AM   #3
Jeff Stout
Liked 706 Times in 283 Posts
I used the harbor freight heat gun and documented intake temperatures and logged et. It did show a pattern and I dialed off of that fairly well. Mine was srt Magnum.
Old 09-03-2019, 09:05 PM   #4
Btp 2332
Btp 2332's Avatar
Jeff were you warming the car up before each round or heading to the lanes, starting it when it was your turn to move up etc. Thank you
Old 09-03-2019, 11:25 PM   #5
Jeff Stout
Both. I would get water temp to the same but intake temp would be different. I would get to know what et difference from morning
to afternoons with the weather changes then look at intake temp and maybe open hood to cool or keep closed to maintain. I wish I had ET book but car was destroyed in accident I didn't keep all the personal, but it showed very good graph of et difference with intake temp change.
Old 09-04-2019, 08:36 AM   #6
Btp 2332
Btp 2332's Avatar
Thank you for your help
