Old 09-01-2019, 01:08 PM   #1
edk68
Default Parts !
9" Ford Strange Axles
35 Spline 41/2 -43/4 BC 5/8 studs
Drive- 23 3/8 Pass 21 1/16
Big Bearing Ford
HSG Length 40 7/8
Strange Disk-Brake Bearing Retainer
$375.
1-750 Davinci SS or Comp. legal
$600.
Mark Williams 6:20,9" Ford Center Section
Large bore (30812") 40 spline spool
Ball bearing pinion support with 1350 yoke
Micro polished, set up by Tommy Le, 6 passes
$1,500.
1 Racepak SC 1000
Eng. RPM, Driveshaft RPM with sensor WOT Volts
All cables and printer included
$200.
1 Set of AVO Aluminum Coilover
18 1/4 CC with Strange Hyperco Springs
150 with an extra set of 130 springs
Great for Street Rod
$150.
1-9 R/P 486 Big Pinion
28 Spline Pinion
$75.
Summer Bros Gear Drive for Big Block Chry.
Great for Nostalgia Build
$175.
Roller Cam for Big Block Chry.
By Comp Cams reground
Valve Lilft Intake.706 Exhaust .676
Duration Intake318 Exhaust 324
$175.
1 Set 14" Wide Centerline Convo with Hoosier Radials
32/13.5/15R
$400.
8 Manley Valves "New"
1.710 Dia. 308 Stem 4.750 Long
$30.00
All Parts plus shipping. NO REASONABLE OFFER REFUSED
Contact Ed 815-909-8827 Text or Calls Please
edk68 is offline   Reply With Quote
Old 09-01-2019, 11:29 PM   #2
camaroinmotion
Liked 6 Times in 3 Posts
Default Re: Parts !
I'm interested in the race pack.. text me. 484 877 1783. And I call you
camaroinmotion is offline   Reply With Quote
Old 09-02-2019, 12:09 AM   #3
Rory McNeil
Default Re: Parts !
Bolt pattern and backspace on the wheels please.
NHRA 6390 STK
M/S 85 Mustang
