Old 08-29-2019, 12:31 AM   #1
Tadshy
Tadshy's Avatar
Default Pro trans help
Anyone with a pro trans what type of fluid and filter are you using?
Tadshy is offline   Reply With Quote
Old 08-29-2019, 03:44 AM   #2
GTX JOHN
Default Re: Pro trans help
Type F fluid...any brand is OK
If you tell make and model of trans I will try to give Filter PN.
John Irving
741 Stock
741 Super Stock
Old 08-29-2019, 11:42 PM   #3
Tadshy
Tadshy's Avatar
Its in an 83 Camaro with a 327. I just bought the car not sure about the trans. How can I tell what type it is. I was assuming it was a 350,
Old 09-01-2019, 10:01 PM   #4
Tadshy
Tadshy's Avatar
I took the pan off today and its a TH350. I can match up the gasket but the filter doesn't look like a normal 350 filter. Anyone have info on where to get a filter?
Old 09-01-2019, 10:23 PM   #5
Eman
Liked 133 Times in 76 Posts
I use a mesh style filter on my 350's with a deep pan with a filter extension. I've used Type F and standard Dexron/Mercon and don't see any difference. Dexron is supposed to lube better and a 350 has a lot of bushings,washers and gears so the lubrication properties are important.
Old 09-02-2019, 12:33 AM   #6
Liked 5,134 Times in 1,958 Posts
Lots of 350 deep pan deals use a Mopar filter with an adapter.
I really don't speak that language, but I I think it's a 904..If not a 727 ..One or the other.
