Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 05-17-2019, 08:28 AM   #1
pfordamx
Liked 7 Times in 5 Posts
Default small round aero scoop
i see alot of the this type of scoop on cobalts and some of the rear wheel drive conversions and i'm curious which one you guys are using our car only does 138-139 in the 1/4 so i think we need a pretty small opening to take advantage of the scoop early. and i'd like something that's not terrible to see over.
pfordamx is offline   Reply With Quote
Old 05-20-2019, 09:07 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: small round aero scoop
If you calculate the area of the scoop opening ,it actually not that small, but its shape helps maintain velocity
Plus it's used on cars that typically have fairly small displacement engines.
The biggest benefit from this style scoop is drag , or rather how much less they have than the older broader style scoops.
I switched to a triangle style inlet ,narrow scoop from the older ,wide style scoop and picked up nearly 2 mph.
Old 05-21-2019, 09:57 PM   #3
pfordamx
tom i'm basicly wanting to play with one in comparison to our factory style ss scoop i think there are gains to be had in this area especially 1/4 mile. and we have a spare fiberglass hood to use with it so we won't be loosing our current setup if we don't like it. i was planning to bolt it to the carb and trim the hood to slide around it.
Old 04-15-2021, 04:32 PM   #4
Chevy55
Banned
Liked 179 Times in 89 Posts
Maybe this will help
http://classracer.com/classforum/showthread.php?t=78917
Chevy55 is offline   Reply With Quote
