Old 03-19-2019, 03:48 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Radial tire question
If you have a 31x13 radial tire how much would it hurt to put the tire on a 15x12 wheel vs a 15x14 wheel? Thanks
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-19-2019, 06:17 PM   #2
Jim Caughlin
Liked 807 Times in 247 Posts
Default Re: Radial tire question
Are you thinking about trying radials with a stick? Not a good idea, I don't know anyone who is having any luck with manual trans applications. My experience was that they hook sometimes and about every 5th run, it would just blow the tires off. Not a controlled spin either, pretty much a total abort situation.
Jim Caughlin is offline   Reply With Quote
Old 03-20-2019, 02:42 AM   #3
GTX JOHN
I have seen no difference between 12 and 14 inch wheels
on 13/31 Tires
John Irving
741 Stock
741 Super Stock
Old 03-20-2019, 02:42 AM   #4
weedburner
Liked 20 Times in 16 Posts
Radials with a stick requires a different approach regarding the clutch and gearing. The clutches you guys typically run would not be my 1st choice, and something like my ClutchTamer is also needed to control the hit.
Since a radial needs to be dead hooked, there's no need for a deep 1st gear ratio to control tire spin. Less ratio in 1st means less torque available to break the tires loose, but that loss of torque at the tire is offset by spending more time in the gear with the most multiplication. More even gear splits also improve recovery rpm, with the side benefit of less energy discharge on the gearchange. Less energy discharge on the shift lowers the risk of breaking the radials loose.
...You need enough mass in the clutch so that it doesn't overheat while you are leaning on it, also need one that doesn't depend on centrifugal assist to hold.
...With a properly controlled clutch hit, you won't need a 2-step and will be able to launch off the limiter without breaking the radials loose. Higher launch rpm means more energy available to get the car moving when the clocks are running.
...Wheelspeed spikes after WOT clutchless shifts need to be minimized with radials, bring those under control by adjusting clutch base.
Grant
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
Old 03-20-2019, 03:47 AM   #5
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Intrinsic value.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 03-20-2019, 08:39 AM   #6
Hacksaw
Liked 314 Times in 177 Posts
From everything I've tried with radials, they always liked a wider rim than the tire. When using a narrower rim I had trouble with bad wobble and less contact patch.
Old 03-20-2019, 11:48 AM   #7
Ed Wright
Ed Wright's Avatar
I use the 13" X 31", on 14" wheels, so I can run more air (13 to 14 psi).
Ed Wright 4156 SS/JA
Old 03-20-2019, 02:36 PM   #8
Mike Rietow
,Wide rim. If you can manage deformation early, you're managing spikes. If you can manage W/S spikes, the potential for leaving tracks could present itself, bridging the gap. Wider wheels than normal?
Old 03-20-2019, 10:37 PM   #9
Ed Wright
Ed Wright's Avatar
Mike, what is a "W/S spike"? I've never heard that term.
Old 03-20-2019, 11:17 PM   #10
Mike Rietow
After the car leaves pause, look in the groove Ed. You can get away with it, bias tire. No wheely bar it's essential to not getting on the bumper. Wheel speed spike.
