Old 02-10-2019, 08:17 PM   #1
J&S Racing
Liked 327 Times in 87 Posts
Default Bellhousing alignment
Ok, I’ve watched a few videos on the process and there seems to be 2 way to do it... I went with zeroing out at 12 o’clock and taking reading from 3/6/&9
After playing with the offset dowels I come up with this;
My question....is the run out 1/2 the dial reading??
So am I 8 or 4 thousand out??
J&S Racing is online now   Reply With Quote
Old 02-11-2019, 12:21 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 281 Times in 78 Posts
Default Re: Bellhousing alignment
Half is correct. You are in good shape. If you can get it tighter that would be better. Video is from Summit Tech.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-11-2019, 07:48 AM   #3
J&S Racing
Thanks Sean!!
Think this is about as close as I can get. Original dial reading was 48 half being 24 so I went with the .021 dowels getting me within .003 best case...
Old 02-11-2019, 11:23 AM   #4
Sean Marconette
Anytime!!! Hope to see some time slips from you this season.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-11-2019, 12:27 PM   #5
FED 387
Liked 336 Times in 183 Posts
.003 is damn close--- unless you futz around all day trying to get closer--then you might throw the other reading off if you finally do get it where you want it-- might also be burrs on the inside of the bell housing opening causing the gauge to read what it's readingFED 387
Old 02-11-2019, 03:37 PM   #6
Jim Caughlin
Liked 808 Times in 247 Posts
Interesting that no one is talking about parallel alignment which I have often found to be off by a mile. The video doesn't mention it either. Don't waste your time doing one unless you do both.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
