Old 12-18-2018, 11:41 AM   #1
Jeff Lane
Liked 12 Times in 3 Posts
Default Hancock & Lane Parts Sale Update
- 383 SBC engine / every part is brand new never run / aluminum heads / polished / carb to pan - flexplate, water-pump, starter, alternator, distributor, etc. almost $8k invested will make 530-540 hp assembled and ready to fire up. Call for pictures ; $5900
- Book 750/850 ; $800
- Book 850 ; $800
- Connecting rods perfect low run v-8 sets ; $200 set
- MSD flying magnet crank trigger system complete SBC used ; $150
- Tons of 3/8” pushrod sets 7.770-9.250 ; $100 set of 16
- Perfect set Jesel .875 lifters for SB-2 drop in ; $600
- 5:28, 5:67, 6:33 - 9” Ford gear sets lightened, coated, cryo’d ; $250
- Mark Williams front brake system / ceramic bearing option. Brackets, Hubs, rotors, calipers, pads. Perfect shape ; $900
- 1 Set new 1.650 titanium valve springs ($1000 new) - $350
- 10 sets used great condition Casidium coated piston pins .866 - .927 many lengths available - $100 set
- 15 sets used Titanium valves different lengths and head diameter. Perfect condition - $200 set of 8
- 8 sets used Titanium Victory retainers 10 degree for 1.500 spring size - $100 set of 16
- 10 sets used titanium Victory keepers 10 degree for beadlock valves 5/16 and 7mm - $50 set of 16
- 20 camshafts 50mm, 55mm, clamshell for SBC Wedge, SB-2 and Splayed valve engines.
- MSD chips 3000 – 10,600 RPM - $5.00 each
- Simpson 5-point harness out of date SFI perfect shape - $100 set
- Tons of Racepak parts and accessories (Collars, pickups, transducers, sensors, Cables, etc. Call for pricing
WHEELS:
- 15 x 10 Alumnastar WELD Wheels, 5 x 4.75 bolt pattern, 5" backspacing, Polished w/ Polished Center ; $800 / set
- 15 x 10 Alumnastar WELD Wheels w/ Screw Holes, 5 x 4.75 bolt pattern, 5" backspacing, Polished w/ Polished Center ; $800 / set
- 15 x 3.5 Alumnastar 1-Pc WELD Frontrunner Wheels - $1000 / set
TIRES:
- Hoosiers BIAS 17.0 / 36.0 – 16 #C2055 ; 1 run - $500
- Mickey Thompson BIAS 30.0 / 9.0 - 15 ; 8 runs - $400
- Mickey Thompson Drag Slick 14.5 / 32.0 – 15 #30751 ; 1 run - $450
- Mickey Thompson 32.0 / 14.0R – 15 #11808 ; used - $100
- Mickey Thompson 33.0 / 14.5R – 15 ; used - $100
- Goodyear Radials 30.0 / 9.0 – 15 ; used - $100
- Hoosier Drag Slick 9.0 / 30.0R – 15 #18212 ; NEW - $400
Jeff Lane is offline   Reply With Quote
Old 12-18-2018, 02:55 PM   #2
MR DERBY CITY
Liked 8,225 Times in 1,538 Posts
Default Re: Hancock & Lane Parts Sale Update
Interested in 28 inch Hoosier drag fronts .....MJ. 502-49nine-014zero......Thanks...
Old 12-18-2018, 10:48 PM   #3
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Interested in MSD chips. Do you have evens, odds or in 100 rpm increments? Sell as a lot? Thanks, Brian
b.guggenmos is offline   Reply With Quote
Old 12-20-2018, 12:16 PM   #4
Jeff Lane
Brian -
Text me on my cell and I will shoot you over a picture of all the chips I have. They are in an aluminum chip holder.
Yes I will sell as a lot.
206-818-1804
Old 12-23-2018, 11:30 PM   #5
6520jr
the 5.28 gears what make are they?
are they new/used ?
if used how many runs?
they are $250 per set?
Jamie Roth
text me at 604 785 4458
Jamie Roth
64 Comet,331cuin,Jerico 4sp
BC Supershifters
6520jr is offline   Reply With Quote
