Old 11-17-2018, 12:18 AM   #1
doug schriener
Liked 7 Times in 6 Posts
Default chev 4-7 firing order change
Hi-This may have been talked about here;if so indulge me-what is the purpose in changing the firing order? Is it because 5 and 7 fire close together? Does it make more power or show a difference in cooling? Thanks for all answers. Doug Schriener
doug schriener is offline   Reply With Quote
Old 11-17-2018, 05:05 PM   #2
1720
1720's Avatar
Liked 2 Times in 1 Post
Default Re: chev 4-7 firing order change
http://garage.grumpysperformance.com...cam-swap.5508/
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 11-17-2018, 09:38 PM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Read the link. The same goes for using a 351 firing order on a 302 Ford where 7 and 8 fire in sequence. It can take some of the stress off the crank. You need to use a cam that matches the firing order, though. I tried just moving the wires and it wouldn't fire...
Dale Shearon
68 Mustang 6394
Old 11-19-2018, 09:19 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Big Cu.In. Hi HP Chevy engines will usually kill the # 4 main if the firing order is not altered. It can also smooth some of the pulses out in the intake manifold, too. The first altered firing order cam I used came from Lunati back in the early 70's. Some guy named Chris told me I needed it.
Draw out the firing order across the intake plenum to see where the air goes as well as the power pulses hit the crank.
Adger Smith (Former SS)
Old 11-21-2018, 01:12 PM   #5
Ed Wright
Ed Wright's Avatar
When I was running (NOT driving!) a 410" "outlaw" dirt track sprint car in the '80s, the 4-7 firing order swap improved my bearing life. Did not test that on a dyno. All I had was a chassis dyno.
Ed Wright 4156 SS/JA
Old 11-21-2018, 04:09 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
I have 3 engines. all have different firing orders. One is standard. one is 47 swap. One is 47-32 swap. All seem to run the same. don't see any real difference the way they run of idle. more of a gimmick in my opinion. all Bullet cams too.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
