Old 07-31-2018, 10:25 PM   #1
Kingpen
Liked 64 Times in 22 Posts
Default Outside of home Division Points
I understand you get to claim 2 out of division races for your total.My question is; if you make 3 or even 4 out of div races,is it the first 2 you get points for or is it the best 2 you finish at?.......also I have been to 5 races so far,but only 3 inside my division,will I get the 30 first round points at my next home division race or only the 10 per round once I go past my worst round finish...haven’t been in this position in several years,kinda forgot how it works....Thanks Victor Penrod
Kingpen is online now   Reply With Quote
Old 07-31-2018, 11:36 PM   #2
GarysZ24
GarysZ24's Avatar
Liked 256 Times in 103 Posts
Smile Re: Outside of home Division Points
If memory serves me correctly, for your first question it's your best 2 you finish at. However, for your second question, I think the 10 per round will only apply above your worst round finish. Your first five divisionals (regardless of division) will give you 30 points minimum for making the first round (as long as you are in the qualified field). You get a total of 8 divisionals per season to collect your best five points finishes from them, so I hope you live in an area where some home divisionals are still available to run (if you want to or can afford them)? There are several racers from home divisions, who choose to collect points at another division (which I can certainly understand, if more of those divisions races are closer to their home, than their home divisions events are?), that's especially true out west here in Div's 5,6, &7.
I moved from Div 5 to Div 7, to ease my travel time/budget thus allowing me to race in more events within D7. That may not be an option for you, however chasing points in that division you went to for the two points meets (if the 3rd and 4th you spoke of are also in that same one), may be an ideal change to collect points from, and those 1-2 in your home division can become the out-of-division points races instead?
Depending on where Div 7 schedules the two races we're going to lose once Rocky Mountain Raceway goes away from us after this season, I may be doing the same thing for a race or two? Good luck with what works best for you!
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 07-31-2018, 11:43 PM   #3
Jody Lang
Liked 92 Times in 29 Posts
Default Re: Outside of home Division Points
It will be your best 2 out of div. You have to count 3 in div.
Being you’ve been to 5 now you’ll start trying to improve on what you’ve done, but if you go to more out of div races you can only improve on your out of div points. If you go to more in div races you could improve on either in or out of races.
Jody Lang is offline   Reply With Quote
