Old 07-23-2018, 09:26 AM   #1
Jeff Swanson
Liked 62 Times in 21 Posts
Default SS/CS accepted heads
If I'm reading the rulebook right any head run in SS/CS must be NHRA accepted. The list of approved heads on nhraracer.com doesn't include any Ford heads for SS/CS. What am I missing?
"All heads must be NHRA-accepted, two valves per cylinder, except in classes DS, ES, FS, and GS, four valves per cylinder permitted."
Jeff Swanson is offline   Reply With Quote
Old 07-23-2018, 10:52 AM   #2
Mike Mans
Liked 299 Times in 48 Posts
Default Re: SS/CS accepted heads
As a Ford competitor, you can run any Ford manufactured factory cast iron heads. They must be accepted if they are an aftermarket casting (Dart, Brodix, etc...).
Mike Mans is offline   Reply With Quote
Old 07-23-2018, 10:58 AM   #3
Jeff Swanson
Thanks Mike, I always thought that was the case, but the wording above (2017 rulebook) threw me off.
Old 07-25-2018, 12:11 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Ford makes a head that fits the SS/CS spec of "Inline iron" called the N351. It is primarily for short track circle track racing. I did a lot of digging on this head and found it on the 1/8 mile record holding Mustang of Venice Perno.
It has a Ford part number, M-6049 N351, so it's not technically "aftermarket". Got mine from Speedway Motors. Require offset rockers and special headers.
links:
http://dragracecanada.com/ontario-ford-aficionado/
Dale Shearon
68 Mustang 6394
Old 07-25-2018, 12:58 PM   #5
FireSale
FireSale's Avatar
Here's some pics of N heads on a BOSS302 block in my 68 coupe. It's a work in progress running in Pro at the moment. I just rebuilt the front suspension and will get it out for competition this weekend.
Mustang by Designer Dale, on Flickr
Engine by Designer Dale, on Flickr
Dale Shearon
68 Mustang 6394
Old 07-25-2018, 01:51 PM   #6
Jeff Swanson
Originally Posted by FireSale View Post
Ford makes a head that fits the SS/CS spec of "Inline iron" called the N351..
No doubt that's the Ford head to run. Good luck with yours!
Old 07-25-2018, 03:56 PM   #7
rawhide
Liked 7 Times in 5 Posts
Ford Performance has discontinued the N351 head and Speedway seems to be the only source of new ones. They must have purchased a bunch of them.
Roland
rawhide is offline   Reply With Quote
